scater shield Question?????
krummel45
231
Apr 23, 2003
Tampa, Florida
I was wondering if you can put on a scater shield with out ripping out the tranny?
Also will the stock flywheel take as much horsepower as you can give or will it brake and at how much power?
thanks
Yes, you can put a scattershield on while the tranny is in the car. It's a PITA with the front water pipe there, though. Just take your time. And a stock flywheel has been used in several 500whp+ cars. Just depends on how much you enjoy using your legs.
so is their a need for a scattershield if you have an after market flywheel if you are running a lot of power?
Im not sure exactly WHY the Flywheel will explode, but I think its from just reving the hell out of it, A stock motor ISNT going to Blow up a flywheel, but a built motor with a 10K starting redline, that freakin flywheel is going to be movin REAL f-eing fast. get one anyways, its not going to hurt any thing, and can only help you.
