Scanmaster w/Wideband
Blue92
119
Aug 25, 2004
Rochester, Michigan
Alright, I may just be retarded here but I can't get my wideband to log with my scanmaster. I tried hooking it up like it says in the instructions but with no luck. I have a 1/8" cord that I got from radio shack to link the two and I am using an innovate wideband, if that helps. I got it to read numbers and change as I drive, but they aren't right and it doesn't log them anyways. Can anyone help me here? thanks.
I had the same problems when I tried it. I was going to try again and to some work to see what the deal was, but I simply have not had time yet.
Alright, I just talked to a guy about this and he said to make sure the O2 is programmed for 0-5 volt output for 10-20 AFR. Mine was not so I changed it. I have not had a chance to test it out yet but will post if it fixes the problem.
As it turns out, the LM1 default configuration is different from 'everyone else'.
Program the Analog outputs on the LM1 for 0 volts = 10.0 AFR, and 5 volts = 20.0 AFR using the cable supplied with the LM1. This will fix it right up.
Regards,
Bob Bailey
Thanks Bob for the continued help with all my questions on the scanmaster. The more I use this thing, the more I fall in love with it. And the tech support is top notch, immediate answers to questions. Definate must for everyone!!
What do I need for that, just a MAP sensor? pm me a # I can reach you at to discuss this further.
