Saturn alt swap on 2g need help what i need.
newtodsm97gst
289
Oct 23, 2011
Lewisville, Texas
I search, but can't find any proper answer. I need diaghram and pictures where to grind it and wiring diaghram. I got a 96 sc2 alternator with 4 pins in it, I understand about not connecting the F pin. I can't find any oem pigtail on any junk yard, is there any other alternative and where can I get it? Thanks in advance. Looking forward from turboglenn.. Thanks..
You re-use your stock tensioner and tensioner bracket. You'll need a longer bolt, i believe 5/16" because the tensioner mounting location is higher up on the saturn alt and the bolt needs to be smaller than the original threaded hole in the tensioner. You will also need the compatible pigtail that plugs into the saturn alternator. For that I called up O'Reillys and they had the universal pigtail that fit. It's a three wire pigtail. Find a belt that fits, I measured how long I needed and brought it to the auto parts store and they grabbed me one. It's an alternator that doesn't fit our cars.....find the gear that makes it work :thumb:
    • Sdcryan1
