SAFC2 Questions
e1337
107
Mar 26, 2004
south berwick, Maine
Hey all,
will a safc2 fix my low idle issues, i heard that when incorperated it can fix any and all idle issues by adjusting the tpm curve? is this true?
thanks
Ron
e1337 said:
Hey all,
thanks
Ron
No. A safc is used to control bigger injectors. It shouldn't be used to help with idle, or vent or to do any of those things. If you have low idle issues, then something else is causing that problem and a safc isn't a fix for it. Fixing the real problem is. Could be your biss screw, fuel filter, vaccum leak, etc...
I used to have poor idling at low rpms when the stock ECU didn't know how to tune the car with the greatly increased air flow and fuel when using the factory maps. After having it tuned with the SAFC2 the car runs perfectly now. Is your car extensively modded without any kind of piggyback computer or DSMlink, etc, to help out your ECU?
ROW
