SAFC Settings for 50 trim and afc
z0n3x
50
Jun 20, 2003
I Just put in a 50 Trim, SBR Front Mount, 660's and a 255 pump. What should my settings be around?
You could use -20% across for baseline, just check your logs and go from there.. no two dsm's really tend to run alike, make your own settings. Just log some pulls to where you have egt's that don't go over 900c, have little knock sum and a good amount of timing.
Originally posted by sp00ln
Would it be the same for 650s and a 190?
Start at -10 across on hi throttle for your setup just to be on the rich side and go from there.
