Safc 2
cookmeup272
1,639
11
Jan 14, 2009
Utica, New York
OK so i installed the SAFC and i was getting familiarized with it. I took the base settings off of RRE and kinda tweaked them a bit. ATM I do not have a wideband but will be getting one shortly. My tune right now is on the conservative side, Not trying to go with the perfect mixture since i do not know exactly how lean I am. My question is, when i start the car it bounces up to like 1200rpm, like normal, but then drops to almost 0! It does this twice and then hovers around normal idle speed(somewhere around 700 or so) Does anyone else have this issue? Is it normal? How can i fix it?
This is a good read for you. I tune by mani pres > converted to voltage
for the safc. Better than false tps position being involved. Less flooding
pre boost this way. Evo scan program & wideband graph on the laptop.
Richer at certain points will remove knock counts & keep your timing up.
It's not just a case of seeing 12:1 right through your rev band on the 02.
http://www.2gnt.com/www/corbin/foolafc.html
Cheers !
Weird...it doesn't do it anymore. Also I will be ordering the LC-1 tomorrow i think on ebay.
can you post a link on where you got your info from?? im about to instal my safc also but im not really familiar on how to use it
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
