Safc 2 question?
coving21
125
Nov 19, 2005
Poplar Grove, Illinois
Okay so I am pretty much stock but hope to have a better setup soon. Here is my question, just installed a safc2 and I have the ne-points at 1k,2k,3k,4k,4.5k,5k,6k,7k,7.2k,7.4k
throttle at 30% and 80%
low throttle never in the negative all positive not exceding positive 7%
High throttle never in the negative all positive not exceding positive 10%
Knock doesn't work because of 2g
So the question is, am I going to hurt anything with these settings?
I hope to go have it tuned soon but need to get the money together first.
In the mean time does this sound okay?
I read in a site that you should set the 1000rpm low throttle at Positive 50%, that's insane right? Mine is at like positive 2%
Any info would be great, yes I have searched the forums but couldnot find what I'm looking for.
Change your NE points to a little less spaced out in the mid rpm range. If you are reving a stock car to even 7000 you are wasting your time. You don't have near the mods to need to adjust the SAFC2. Just leave everything zero'd out at low and high throttle until you get some fuel and boost mods.
Thanks I figured thats the answer I would get is 0% low and high basically stock settings?
