SACF2 Problems
ttsrq
75
Sep 8, 2006
Kelowna,
So awhile ago I installed my SAFC2 and zeroed out my settings because I was running the stock fuel system and everything worked fine. Today after I installed my fic 650's, wally 255 and AFPR.
After going through my settings and getting my low trims as close to 100% as possible and carrying over the settings to my high throttle. I noticed that my SAFC2 was "sticking" on the way home. What I mean by this is that the screen that shows the correction factor, rpm,throttle positon it sticks...so if I punch it and left off the throttle position and the rpm will stay at the point where I let off the gas. They will stay there until I go into the display settings and bring it up again it will work properly. Every time it sticks I can get it to stick at a higher RPM or throttle by increasing it higher then the previous throttle amount. Any one know what could be causing this?
An safc has a peak hold feature. I am not sure which button it is, but it can be turned off. I would thumb thru your instruction manual, or download it if you dont have it, to see how to switch it back.
