S-AFC and Emissions
awdclipse
42
Dec 18, 2004
Germantown, Maryland
I have heard of people using their AFC's to help them pass the 'dyno style' emissions test. What exactly do you have to do (leaner)? and specifically effecting how much of the hydrocarbon? or does the a/f ratio effect a different type of emittant like the NO's?
I have high hydrocarbon #'s which is greatly effected by the cat, i was told with 3" exhaust the flow is too high which does not produce enough friction within the converter to make the necessary amount of heat to work properly. Has anyone had this problem with 3"?
Thanks for the help
Thanks for the help
i just passed emissions on the dyno with everything on my safc left the same, only thing i changed was put the stock d/p on.
