KFred 513
- 146
- 0
- Oct 11, 2012
SUllivan,
New York
So I know a lot (almost all up to date threads) say to leave base timing at 5*btdc When using the 1g cas. I found that no matter what I do with timing set to 5* btdc I cannot get the car to run right at low rpm.
I got my car running better than ever down low at idle and light cruise by adjusting my cam gears along with spending some time on link.
I realized this must have been partially due to my base timing changing with the intake cam. I bought a timing light and set my base timing to 5* btdc and the car would not run right no matter what.
Idle was choppy, it had a slight 150 rpm surge from erratic timing adjustments. Also low speed manners were horrible. I idle my car in open loop so I made timing changes from 5* up to 12* in the DA table. Adjusted AFR from 13.0-14.0. I made all sorts of dead time/ VE corrections to get airflowperrev to where it should be but nothing worked.
I decided to adjust the cas "by ear" and my idle immediately smoothed out. I advanced it some, I still need to check to see how much but the car is running great again. I had to get my tune back in order but it only took a few minutes compared to the failed hours spent with the cas at 5*.
I guess my reason for this novel is to ask if anyone knows why/how base timing can have such an effect that I couldn't get it to run right with link. It just seems like something else may be going on that the added base advance masks?
