1G Running dual rail setups?
I like to run identical size pri and sec. If one fails it cuts fuel in half and the cylinder just quits. If you run say like 1650's and 450's if a 450 quits, you go slightly lean and burn it down.
Back in the day, before I fixed my harness, my inj clips were missing the springs. I had several passes a wire came off in 4th gear. How many times could that happen without melting it down if I had secondaries 20% of the fuel of my primaries...
Hey, how do u have your injectors wired in? I plan on using the forced
Four injector driver. Did i read your post correctly when you said u wired them in without anything
  • Wanted 6 bolt NT water pipe
    • chrisman287
