Dual fuel rail?
i know this is old but does anyone know how he made or where he got the piece that goes on top of the tank that the pump attaches to? or does anyone know his email?
Maglin said:
but you would want to run a new injector controller as the power demands for the additional injectors will eventually blow the injector drivers insdie the ECU. This is very common in the GM-ECU world where people try to run the 7747 with duel TB's and end up blowing up a very good ECU cause of the extra power required to run the other set of injectors.
To anyone reading this thread, heed this advice. DO NOT TRY TO PIGGYBACK EXTRA INJECTORS BY WIRING THEM IN PARALLEL ON A STOCK ECU. The drivers (read: transistors) are NOT built to sink the added current.
  • Wanted 6 bolt NT water pipe
    • chrisman287
