Running a little learner while coasting/smoke from exhaust
Rikolas
368
May 6, 2012
Seabeck, Washington
Recently I've noticed while I'm coasting in neutral that my wideband has been jumping around from 15 to 16.5. While at idle at a stop it reads around 14.5 to 14.8 or so. Anyone know what causes this?
Also, sometimes I'll get smoke from my exhaust. It doesn't happen all the time, almost random. It happens more around the time if i start it up after about a minute or so of turning it off (noticed this while out looking at garage sales).
Any help will be appreciated. Thank you
edit: title should say leaner, not learning. sorry
my lc-1 does something similar, during a coast mine will lean out completely up to 21.9 and then once the RPM's settle it will go back to normal of around 13.4-14.8 when sitting at a stop light. I'm curious on this issue as well, mine doesn't smoke or anything, but i'm curious as to what causes the A/F to shift so much.
Yeah, I'm pretty sure that my two problems aren't linked. My exhaust did this before my afr was bouncing like that. I think that after searching a little bit more that it might be a turbo seal, but I've also heard that you cant rebuild a ball bearing turbo.
I know absolutely bupkiss about turbo rebuilds, JusMX is the guy you want to talk to about that. He's a pro with rebuilding (currently building my 20g for me :) ) as for the smoking, can you see what color it is? that's usually a tell-tale sign if its blue smoke then its related to your motor, if its white-ish then its turbo related. I know thats probably not what your looking for, but its a start.. LOL
I think that when you let off the gas and coast it normal gives a lean condition, the smoke could be your seals on the turbo to much oil pressure can cause smoke to come out the exhaust from the turbo being over oiled.
The lean condition while coasting if your over about 1200 rpm's with the throttle closed the ECU sees this and cuts the fuel injectors to zero. When it hits the 1200 rpm's it will go into an idle loop. There's an article on here about gas mileage and it describes this as a way to save fuel and engine braking.
The smoking on start up could be old valve stem seals. I have same issue only minor though and only on start up. If your exhaust valves are leaking you can usually see signs of it around your exhaust manifold. It appears damp. There's different conditions and signs that tell you whether it's piston rings, valve stem seals, or turbo seals. But from what I gather it only being on start up sounds like the valve stem seals.
I think its a white color of smoke. And it can also happen while in town driving, it is just more rare to see it. And there mignt be a llittle leak from my exhaust manifold, since I did notice one bolt looking damp. Thank you guys for your help. Ill look into all of the ideas.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
