runnin 20psi hot 26psi cold on stock sys
98gst14b
453
Jan 24, 2006
Keys, Florida
Cant figure out why my boost is so high its on stock acutator with 14b turbo/wastegate. Dont get me wrong its fast but I do believe 20 psi is dangerous.....also this 0-60 thing tells me im runnin 8.2 hmm can u say spinnin tires?
so you have the wastegate connected directly to the source? or are you using a mbc of sorts(or the stock bcs?)
20psi is alot to run with no fuel mods listed. 26 is alot even with fuel mods. i would stop going wot till you get this issue resolved.
on a hot day, air is less dense. on a cold day, its more dense, and thus when boosting, it will be compressing more air than usual. but a proper boost control device will still regulate 20psi hot or cold. the only time youd read a difference in temps is when logging airflow or intake temps.
if you are using a mbc, you are getting some insane boost creep.
I 2nd that. What kind of boost controller are you using? if any? I would advise not to run the car hard at those boost levels. Also, are you sure you have you boost gauge set up properly?
