rpm's randomly fall
miller97tsi
221
Jan 5, 2008
jacksonville, Florida
well every once in a while when i drive i get the rpms up to about 5000 and hit about 16 psi let off the accelerator and the rpms fall to 0 then comes right back to where its supposed to. any suggestions?
its really hard to say what the problem could be considering i dont know any of the modifications that you have on your car it could be something as simple as a wire shorting out somewhere.
maybe check the ecu see if the caps are leaking.
It could really be anything a bov(unlikely), short, bad ecu caps, fast idle valve, IAC. I would start at the least expensive thing and check your connections and look for any bad or worn wires.
  • Wanted 6 bolt NT water pipe
    • chrisman287
