Rpm drop
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
I got my car tuned after adding some parts and now at idle(mostly when the car is cold) the rpms will drop low and my wideband will read lean. It will cut off sometimes and when I crank it back up it idles fine and my widebands read 14's for the most part but will go into the 15's and 16's. Before the parts and tune my wideband would stay in the 14's when cold and didnt cut off, but when warm it would be in the 11's at idle. Is this a problem?(the new tune not the 11's thing)
A proven member with almost 5000 posts asked for a log so he can figure out where your tune is off.....and you are asking for a second opinion?!?! Unbelievable.
Good luck o.p.
Good luck o.p.
I'm a proven member and spends hours a day on here and just learned how to change my tranny fluid.....so to answer your question, yes.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
