Rough idle after o2 replace and rebuild
TrystanGST
573
Jul 29, 2004
Chicago, Illinois
A quick run down -
The car broke it's timing belt a month ago and bent 10 valves.
The head was rebuilt, and I put in many other new parts, including a 1G CAS.
After chasing down some blown fuses, I got the car started. It idled at @700RPM and Link showed no error codes, but the o2 voltage was flat at 0.04v. Shortly after, the DTC 0135 came on, and I knew it was time for a new o2.
I replaced the o2 and now when the car starts the o2 voltage climbs to 1.02v, but the idle is down to 450-500. If I give the car gas, the engine responds, but once the revs drop below 2000 the car bogs and will stall if you don't keep your foot on the pedal.
A few other notes - idle switch parameter reads 0-, and the throttle reads 5%.
I plan on doing a BLT, as well as looking for what sounds like an exhaust leak I hear coming from under the upper heat shield.
Am I on the right track?
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
