spyderdrifter
- 5,434
- 864
- Jul 11, 2009
Somewhere in,
Colorado
So I was just searching around for info just to knock dust off my brain for upcoming work I'm goingto be doing, and came across this post: http://www.dsmtuners.com/forums/bolt-tech/97931-honing-cylinder-walls.html#post797464
Post #6 states putting assembly lube on the crank journal side of the bearings ONLY. Is this correct or should I lube the other side too? I'm only asking this because I can't remember which way I did it with my old 7-bolt. If it's only supposed to be lubed on the one side, and I ended up doing both, that could explain some things. Again, only asking this for verification since it'll beinvolved in my upcoming engine work.
