RNR O2 elimiator downpipe
goshred005
Sep 30, 2004
honolulu, Hawaii
will the RNR o2 elimiator down pipe fit the Evo III 16g? if not, then will the RNR 3" downpipe fit the EvoIII o2 housing? thanks . :confused:
yes it does but i would suggest installing a oil filter relocation kit at the same time you install the downpipe. it's a close fit.
but will the 3" RNR downpipe fit the Evo III O2 Housing? Would i have to port the O2 Housing because isnt the O2 housing 2.5"?
if you decide to upgrade turbo's to a bolt on 50 trim or something similiar, it will not fit. i was able to use the evo8 filter as well when i had a 16g, but as soon as i put on the 50 trim, that baby was not coming off. it moved it just enough towards the filter to make it not possible. i would get the relocation kit, it's also a lot easier to change my oil (don't burn ## hand on the exhaust or nething like that), plus you get to use a bigger filter.
