Rix Racing: Jmfab T3 Manifold / Borg S369 combo & DSM parts — 2026-10-29
dacowgod
Supporting Vendor
460
288
Feb 3, 2006
Morgantown, West Virginia
Here’s this week’s mix of DSM parts at Rix Racing:
Numbers match the photos.
1. Jmfab T3 Manifold / Borg S369 combo — $2,200
Borg s369 sxe billet t3 turbo
jm fab t3 exhaust manifold
hood exit exhaust and dump
Tial wastegate
Photos, details & availability
2. ETS Race intercooler for 2g DSM — $1,000
Used 5.0 thick 2.5 inlet/outlet does come with lower pipe.
3. Megan racing street coilovers 2G 95-99 has 32 levels of adjustment. — $550
Used has some rust on springs see pictures boots in good shape.
4. Precision 6766 Journal Bearing — $850
Freshly serviced PTE 6766 Journal Bearing in .84 divided t4 housijg
5. Garrett GT3582r — $850
Genuine Garrett GT3582r Open T3 Dual Ball Bearing - healthy used unit in good working shape!
6. Magnus Launch Control Device / Clutch Slipper Valve – Used — $300
Used Magnus launch control device for adjustable hydraulic clutch release.
Includes the solenoid assembly, adjustment valve, attached hard lines and fittings, mounting bracket, and wiring with connector.
7. Magnus DSM Remote IAC Relocation Adapter with Idle Air Control Valve — $150
Magnus DSM remote idle air control (IAC) relocation assembly with a machined aluminum housing and installed IAC valve.
Includes two brass elbow fittings with hose barbs and the installed valve mounting bolts. Housing features an engraved Magnus DSM remote IAC marking and mounting holes.
Used, with surface scratches and scuffs on the aluminum housing.
8. TiAL Blow-Off Valve with Aluminum Charge Pipe and IAT Sensor — $225
TiAL blow-off valve mounted on a straight aluminum charge-pipe section with an intake air temperature (IAT) sensor.
Includes the silver-finish blow-off valve, vacuum hose fitting, mounting flange and clamp, aluminum pipe with bead-rolled ends, and installed IAT sensor with welded bung.
Used assembly with visible scratches, scuffs, and surface discoloration on the valve and pipe.
9. K&P Engineering Reusable Oil Filter for 4G63 – Black — $125
K&P Engineering cleanable, reusable oil filter for a 4G63 engine.
Black finned housing with removable stainless steel filter element and magnetic pre-filter. Includes the housing, filter element, spring and installed sealing ring.
Used, with surface scratches on the metal end plate and small nicks in the black housing finish.
10. 2g 95-99 bumper support brace brackets — $100
Used freshly powder coated black
11. OEM 1995–1999 Mitsubishi Eclipse (2G DSM) front bumper reinforcement mounting brackets — $100
12. Mitsubishi 1g OEM BOV md160689 (NEW) — $175
New in box discontinued
13. Injen recirculating intake pipe for DSM — $175
Used freshly coated black see pics can see some pitting through the coating
14. 2gb CAS setup with stm cover. — $150
Used with sensor
15. 2g DSM 95-99 carbonetics rear bumper diffuser kevlar blue. — $450
Used condition has some minor scratches
16. Fp race manifold DSM 1g/2g 90-99 — $350
Used freshly coated black.
17. Fluidamper steel crank pulley 4G63 DSM 1g/2g (603701) — $325
Used good condition
18. 2g 95-99 DSM left & right strut forks powder coated black — $100
Used powdered black not us..
19. AEM Boost gauge — $130
Used good working order
20. RTM evo 3 coil bracket with coils — $100
As titled
21. 2g Ac condenser — $125
Used good shape
22. Innovate LC -1 wideband — $120
Used has scratches on gauge
23. Aeromotive AFPR — $100
No fittings
24. Red Perrin Fuel Rail - EVO — $100
As titled!
Morgantown, WV. We ship worldwide. Photos, details & current availability: https://rixracing.com/?utm_source=d...aign=inventory_2026-10-29&utm_content=roundup
In-house dyno & automotive machine shop, CNC machining, powder/ceramic coating, engine assembly and DSM builds/repairs. We can help arrange transportation. Shipping and any listed core charges are separate.
