Rim offset question
bam22056
Aug 15, 2014
Newton, New Hampshire
So I am picking up a set of Kosei K6R's (17X7) that are listed as having a 38mm offset, I have heard that stock 2g wheels have a 46mm offset. Will going down 12mm cause any rubbing by bringing the rim closer or am I not understanding this whole offset thing properly? Ill be running the stock tire size for awhile, then going up to 225/45/17 after a while.
I don't have any suspension modifications at the moment, but might in the future if that comes into play.
All the others I was looking at in my price range were 7.5, but when I saw these weighed 6 pounds less than the second lightest one I could find I had to.
Thank you! So if I'm looking at this right, I'll have more clearance between the fender and the wheel than with the stock wheels unless I run wider tires, right?
  • Wanted 6 bolt NT water pipe
    • chrisman287
