Rewiring Infinty system
drewvr4
496
8
May 28, 2005
Hendersonville, North Carolina
Alright ive put in my new head unit, wired it up to the factory harness.
Now ive pulled the seat and got the amp out of the way, and im left with the large harness that comes out of it. Now does anyone have a diagram on that part, I need to figure it out so i can bypass the amp, thanks!
are your speakers not working with the amp removed? I just installed a kenwood head unit last week and it worked fine with out the amp being connected and nothing bypassed
yea you can just leave it unpluged like defiant said and i did
What setup are you running? Speakers powered off the head unit? Or by amp? Check vfaq, if you look under wiring diagrams it has colors for all the speakers.
A few things to check. First is the radio powering up? Second how did you connect the radio, did you get harnesses to plug in or did you tap the wires? If you tapped the wires make sure you have the right ones connected and secondly make sure you have no wires poking out and touching anything that will cause the radio to power up but will not allow any sound if your speaker is grounding out.
