reuse the 2g cas in ## 6 bolt swap?
Ilikespeed
Jul 12, 2008
davenport, Iowa
Can I reuse the 2g cas in a 6 bolt swap? All of the threads have said 2 use the 1g cas... Y can't u use the 2g???
only if you using a 2g head, other then that, 1g 6bolt long block, you will need a 1g CAS and a harness from RRE.
Just use the 1g CAS. It's really not as hard as what it seems. It would be much harder to make the 2g cam and crank sensors work with the 1g motor IMO.
I hear most people run the Hall Effect black CAS, is there a reason for this over a stock looking one?
