retap crank treads
rmTSI
Jun 18, 2007
Tahlequah, Oklahoma
there was a alfull noise coming from the motor, so i droped thr trans and found that the flywheel bolts had backed out all of them but one so i pull the flywheel off and see that the threads have been worn down, so i was woundering if i can retap them, helicoil them or just replace the crank the motor was rebulit 3000 miles ago and not sure if i should replace all the bearings or not
