[RESOLVED] Underdrive belt size
I would wait till you get the udp. On the ps/ac side mine will only accept 4 rib (suppose to be 5 rib). Get the gatorback belt or gates. Belt size should be 49.5 inches
The AF/X UDP comes with the necessary belt which is always nice of them. What made you decide to go Unorthodox instead?
They shipped stock size belts with my AF/X UDP... maybe it was a mistake on their part, but as I said before, the stock belts do not fit.
I bought mine from Howell a little over a year ago and everything seemed to fit just fine for me. I never really payed attention to the size, just assumed they were correct but I didnt have any problems.
I went to the unorthodox racing web site and got the suggested/recommend belt size of the installation page. Thanx for the help this comming friday my ride will go into the shop for timeing belt, pulley, and other work.;)
:thumb::dsm::talon::laser:Well the work is done. It seems to me that all ready the ecu has made the adjustment for the new pulley. Is this normal? The engine revs quicker, and it feels stronger.:sneaky::cool:
The ECU doesn't know the pulley is there. The snappier revving and extra power is from freeing up power that would usually be used to turn accessories.
This is usually the reason for using an under-drive pulley. Your results are as expected.
According to Unorthodox Racing's website, the proper belt for the alternator is a Gates K040320 (32.75 inches or 830MM). The Power Steering/AC belt is a Gates K050490 (49.5 inches or 1255MM).
Just had to look it up for a friend.
