[RESOLVED] rear main seal fix
Status
Not open for further replies.
the seal is like only 7 bucks, but the trans has to be dropped to do it.yesterday i took out a fwd tranny, put new clutch fork pivot ball in, and the whole job took me like 2 1/2 hours. by myself. but i also had a engine hoist to lift the trans in to place. so to answer your question, a shop will prob charge like 300 to do, but you would be better off doing it yourself
You can remove the tranny from the bottom without a hoist. The hoist just makes it easier. Search around for "removing tranny"...there are a lot of posts on different ways of going about it.
BTW - There is a lot more to doing a 5 speed swap (I assume you mean going from auto to manual) than just dropping and reinstalling the existing tranny. You basically have to remove the dash to install a pedal assembly, as well as the clutch cylinders and plumbing.
And while I have the trans out I might as well build the engine. I can get parts from manley for a very cheap price soo..
I'm aware that a 5 speed transmission does not just bolt up and work without installing the needed accessorys.
Status
