[RESOLVED] Question on Hallman ES MBC
chico904
1,347
7
Feb 9, 2004
Pittsburgh, Pennsylvania
Ok i disconnected it last night to run a boost leak test, and am trying to hook it up again. I don't have the instructions anymore, so I forget, do you back the screw all the way out counterclockwise, and start to turn it in clockwise to raise boost? Or the other way?
Also, since there are no markings on it I dont know which is the inlet/ outlet. Does the barb that is parallel with the adjustment screw go to the compressor, and the barb that is facing down go to the WGA?
Also the fitting parallel from the knob goes to the wastegate and the one on the side goes to the pressure source.
It's actually the other way like I thought, thanks anyways though.
on one of the air nipples on the BC, theres a small hole, that one goes to the WG solenoid the other goes to the compressor housing. I have the same one
