JMiller
- 684
- 1
- Jun 30, 2007
Irmo,
South Carolina
OK when i pulled into my driveway today i realized some oil on the ground around where my oil filter is. So i lifted the car and could see the oil dripping from the filter and the oil cooler. So when i moved it a little both the filter and the oil cooler were loose. The oil cooler wasn't that loose but i was lucky to catch it when i did, the oil filter was maybe a day away from falling completely off. I read the thread for this saying i need to tighten the oil cooler bolt(but not too tight). My question is can i remove the oil filter and tighten the bolt without doing a whole oil change. Its a 98 GST and i use OEM filters with Royal Purple 20w50 oil. Oh i hand tightened the filter as much as i could and everything seemed good and tight(nothing was moving at all any more)
Thanks
Thanks
