[RESOLVED] Erratic Front o2 volts? DSMlink log attached [Resolved]
ApexVIII
812
5
Jan 12, 2008
Modesto, California
look at my front o2 volts.
my car idles really lean after pulling the head/timing belt and installing 264/272 cams
any ideas? i am doing a boost leak right now, and the compressions is 180 for all 4 cyl
ok, i just cant figure out why it is running so lean at idle, befor the cams it was cycling around 14.7
there is no boost leaks, there might be a leak at the DP, ill check that right now
i think i found out what was wrong...
when my friend put on the DP, one of the studs was mesed up, so when he tighend one side it went down all the way,
when he did the other one he tighten it almost all the way then it stopped and he thought it was done, but i had a exhaust leak there so im hoping that is it
im gunna go look for some replacement bolts for it
thanks for the input!!
Fix that and I guarantee your wideband readings will be closer to normal.
I'll also suggest that you switch over to the new V3 application. We maintained backwards compatibility with all our previous chips dating back some 7+ years. So there's really no reason not too. You'll get a MUCH cleaner interface and much easier navigation features.
ECMTuning, Inc.
Thomas Dorris
Awesome. Would you mind clicking on "thread tools" and mark the thread as solved?
