[RESOLVED] CAI question
Tor-Lein
38
Nov 22, 2006
Slemmestad, NORWAY, Europe
Quick question..
On my CAI there are two holes where hoses are supposed to be attached.
One for the Valve cover (left one, see image), and another one closer to bumper. (Right one, see image)
The one on the right (nearest bumper) is bigger, and where is that supposed to go?
I did not get any installation instruction..
Here you can see the two holes, one big one small. Small attaches to Valve Cover..
Big attaches to what?
Try a search for "Pulsed Secondary Air Injecton"
Or here's a quote from Driggs;
95 2GNTs came with a PSAI system. It's garbage and there is a recall to have it removed and the ECU reflashed to run correctly after the fact. This is one of those situations where all you have to say is that the 2GNT intake only requires (1) fitting to supply vacuum to the PCV system. Any other fittings should be capped off, as they are not needed.
To call it a breather hose fitting without mention of the PSAI system is on the weak side, even though, technically, that's all it really is. It's all moot anyway. Why are there STILL multi-page threads about intakes on NTs?
People. It's a pipe. There is a filter on the end of it. This is not rocket science. Get a cheap pipe and quality filter. Think for yourselves! The gains associated with CAIs are NOT worth the trouble debating. Pipe. Filter. Done.
