Replacing the ISC
dylan71971
52
Jul 11, 2008
Hannibal, Missouri
How do you go about replacing your ISC? Can anyone give me like some step by step instructions, or post a link to some, I have searched and couldn't find anything that showed anything about replacing it, only about testing it.
Its pretty plug and play. Find those threats about testing it, so you can see where its located. Remove the 2 screws that are holding it to your throttlebody, unplug it, and make sure that the o ring that it has is in good shape or replace it. put the new one on, and plug it in. good to go
QUOTE=davidalindsey; How do you adjust the ISC?
I Just put a new ISC motor in there, I have installed and reinstalled that thing so many times now.
Is there a certain way they have to go in?
QUOTE=Ceddy; You have to center the ISC if a new one is installed. Check the FSM or search for a FAQ. You have to put the ecu in ISC adjust mode with a logger/scantool.
(Called Speed Adj. Screw Mode in EvoScan)
From thread:thumb:
thanks, maybe i should read the title of the thread when my search comes up with random posts.
