replace original seat - seatbelt info
caolord
Dec 26, 2004
Trieste, Europe
Hi to everybody
i have a question about replacement of original seat on my 1g eclipse.
i am going to order new seats from recaro. I know that i need also sliders and brackt.
this is my question. I have to keep original seatbelt, in agee with italian laws.
Original seatblets are bolted direclty on seat, and if i remove original seat
Where i can install it? i have seen on e-bay that same brackets came out with new place for seatbelt is this right?
thanks a lot
Luca
First, I don't think Recaro makes sliders to fit 1g dsm's and I don't think I've ever seen brackets for adapting the stock lap harness (assuming you have the sliding belts)
The Canadian cars had conventional one buckle 3 point belts that may be easier to adapt. Are you sure you can't switch up to an FIA approved seat and harness combination? If not you may just need to stick with a stock seat.
i explain my problems.
in italy is really difficult to find out part for 1g dsm, and original stock seat is very very expensive.
So i think to install recaro seat and slider on a specific bracket for 1g dsm, and to create another bracket where i mount the lap harness.
Please, if you kow some solution (not fixed seat but similar to factory as funcionality) can you suggest me something?
Many thanks
