Removing Turbo
drc1
66
Jul 14, 2003
Tampa, Florida
As you can see I have a 92 Laser AWD Turbo with the stock 14B turbocharger. I'm getting ready to remove the turbo tomorrow and I was just wondering if there is anything I should know before I get into it? I have the Haynes's repair manual for my specific car and it looks like a pretty straight forward job. If there's anything I should know ahead of time like certain hangups or problems that are common in the removal/installation please tell me!
Thanks :laser:
Soak all the bolts in PB Blaster the night before. Then, when you are ready to remove, let the motor run for about 1 minute, then break the turbo to manifold bolts loose. Works good for the downpipe nuts as well
There is a way to JUST remove the turbo without removing the manifold? If so please tell :) The book I have says to remove the exhaust manifold along with the turbo...
NOSLO2PT0 said:
The turbo is held onto the manifold with just 4 bolts. www.vfaq.com is your friend
Doesn't it come from the factory with 2 bolts and 2 studs? On my 96 it did... I swapped them all out to bolts.
Maybe it's a 2G thing, I honestly have no idea.
  • Wanted 6 bolt NT water pipe
    • chrisman287
