Removing Emissions - FPR
604CruisinCroat
366
4
Feb 17, 2003
Vancouver, BC, Canada
I've removed all my emissions including the vac lines to the fuel pressure solenoid.
I have the stock FPR and it has 2 nipples on it....where do they connect to?
The bigger one is your fuel return line, the little one is for the solenoid, or you could bypass it and connect to the intake mani.
Here you go. The stock FPR is just out of camera view but you can clearly see the big nipple goes to the fuel return line and the smaller nipple you connect directly to the intake manifold as seen in the pic.
