1G Removing ABS wiring
silentsnow31802
213
163
Sep 23, 2022
California
I am in the process of removing the ABS from my 93 GSX and im having a hard time figuring out what wiring I can actually remove.
From what ive read there is an ABS harness that can be removed all together but looking through my car that harness is either part of another body harness or has a LOT of wiring in it.
I removed the two plugs from the ABS module under the hood. One plug was easy and looks like it was just power. The other goes through the right-side fender well into the cabin of the car.
Is this ABS only or is there other things in there I need to worry about? I assume it's just ABS because the connector only went to the ABS pump, but I want to make sure before I get impatient and start cutting things out.
I have found the ABS control module under the right-side B pillar and removed it. There was a large connector going to the module itself which I can assume is ABS only but there are two other small items that remain. Relays perhaps? I do not know if these are part of the ABS system or not. They are in the same harness. Also, this harness has quite a lot of other wiring through it. Ones seems to go to the right-side seat belt at the very front end of it where the latch would be if the door was open.
