Relay For Memory of Your Stock Head UNIT?
DSM_ThuNDeR
565
4
Feb 28, 2008
Salinas, California
Ok... lately every friken time that I turn on my car I have to puch in the stock head unit code because it erases it memory... I have check the alternator fuse, and also the AOD or somethit fuses(UNDER THE HOOD). This is seriously getting on my nerves. I wanted to know if there is a relay that controls that, ALSO The security and open door light(WHILE DOORS ARE OPEN) on my gauge cluster don't turn on! any input on this guys?
Here is the thing about the radio not keeping memory. I had the same problem with my stock unit and that was because the memory wire was loose. The thing about the door ajar light it depends on rather you have keyless entry or not if you do and don't have the remote for it,it will not come on unless you unlock it with remote. Now if you don't have keyless entry and it doesn't work then it's the bulb. Check the wires and stuff on back of the radio and also if you just got that car. The way to check for keyless entry is under the dash right side it has 2 computer hook ups one that is clear and the other one is black the black you want to see if it has a metal connector in pin in and if it does you have it just get an remote from keyless ride and you will be good with that and it's more and likely the three key remote.
does anybody know or have a link on which color of wire for memory on the stock head unit is(2G's).... this is soooooooooooooooooo weird. I had the stock alarm activate and these stupid things started to come up.
I will have answer for you 2day about what color is the memory wire. Another you can find out is go buy a wiring Haynes for installing an aftermarket radio and plug it up to the factory harness and then you will know because all the wires match to each other. If not I will send you the information later today.
does the keyless entry have to do with the beeping noise(when the key is in the car)??? I forgot to mention this stoped working... and the car WILL lock if i have the key in the ignition... :( please help
There's a sensor switch in the ignition tripped by the key. That wire may have been cut in order to make something work with the key out.
Check your door switches for the dome light troubles.
