redline and efficiency ?
spoolin_92
Nov 14, 2004
lisbon, Maine
I have a 92 tsi fully stripped and going to be basically race but street driven. I ahve a stock bottom end with j&e pistons bore .020 over arp studs, titanium springs and retainers. 272/272 cams im going to be running a 20g with 660s vpc afc aeromotive fuel pump (fuel cell on the road oh ya :shhh: ) I was wondering what redline the motor and handle and what the efficiency of the 20g with 22-24 psi will be thanks for the help.
Your getting head work done as well right??? With those cams you can pull up to 8500 if you want its all up to you really. You will find out your shift point when the engine stops pulling.
Just remember the higher you take the motor the more advanced wear will occur. With those cams you will want to get stage 3 head work with oversize valves and upgraded springs, and a full 3" exhaust to see the full effect.
I agree im getting a full port and polish on teh head but im staying with stock size valves
