PaulPDX
- 884
- 2
- Oct 11, 2003
LA,
California
Hmm... that is pretty loud contrary to what I've been told. Hopefully that additional resonator I asked for will help.
And, it's a 4 banger. You can't compare it to a 6 or an 8. Pretty hard to make any 4 sound good. The bullet muffler and the 4" tip doesn't help either. The large tip works like a megaphone. If I remember my high school AP physics and college physics courses correctly, the large diameter tip has the effect of increasing amplitude (volume) and decreasing frequency (lower tone). If the tip was smaller the pitch probably would've been a little higher. You'd be amazed how much of a difference in sound exhaust tips make.
The sound is pretty similar to my friend's 2G with a Tanabe exhaust (similar muffler and tip).
As far as boost creep goes, are you still on the stock O2 housing? If you went with the O2 elim I don't see how it could cause creep since exhaust vented by the wastegate has a less restrictive path to escape. Perhaps you need to install a bigger valve on the wastegate. I came across the instructions to do this somewhere, sounded like a pain. A 16G will take care of that. :laugh:
I backed the mbc out some more and it didn't seem to help. Around 5k it hits 15-16.
Oh well, give and take. Having awd + turbo is a nice alt. to a big v8 and rwd. :thumbup:
