Rebuild Kit
Ronnie01
161
Jan 11, 2003
South Point, Ohio
I plan on getting the Hahn Stage 2 Turbo Kit. My car has 109,000 miles on it and I figured that I should go ahead and rebuild it. I heard that my stock engine could handle this turbo kit so where should I buy a rebuild kit and which rebuild kit should I buy?
:talon: ESI 2 TSI
Ronnie01 said:
Which one?
:talon: ESI 2 TSI
depends on what you want and what you want to spend. but definatly dont get the stock rebuild, comes with stock components, so that wont help you. if you have the cash, get the stroker. adds displacement and gives you stronger rods and pistons. if you dont have so much cash, just get the rods and pistons. when im rebuilding, im going 8.6 compression. it give you a little bit of a power loss over stock, but then you can turn you boost up much higher, which makes up for it. so it all depends on what you want to do.
tell me what your goals are and ill help you some more.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
