razza
- 1
- Feb 12, 2003
Christchurch,
New Zealand
Hi all,
I had the first go at the dragstrip on the weekend and did pretty terribly. The Evo Zero 3.909 ratio gearing might be partly to blame, probably as much as my shitty driving, but another issue is my 7500 RPM limit. My tuner set it there as the car stopped making power about that point. Full boost is at 5250 RPM and with the rev limit where it is it gives the car a very narrow powerband. So with the mod list below can anyone see anywhere which might be causing power to drop. One item that has crossed my mind is the intercooler. Its a 21x9x2.5" chinese style. I had the inlet and outlet changed from 2.25" to 2.5". Could this cause a drop in power up top when the turbo is really starting to pump.
Mod list is below as well as dyno graph. Any advice greatly appreciated. Cheers!
9.0:1 forged pistons
Aftermarket rods
ARP head studs
Cometic head gasket
ID1000 injectors
300lph fuel pump
Fuelab fuel filter and adjustable fuel pressure regulator
Forced Performance GT35R with 0.68 exhaust housing @ 28psi
JMF Race Inlet Manifold
Larger intercooler w/ 2.5" intercooler piping & Tial BOV
Degree'd Kelford 272 cams with dual valve springs
3" Exhaust
Standalong ECU
Aftermarket rods
ARP head studs
Cometic head gasket
ID1000 injectors
300lph fuel pump
3" Exhaust
Standalong ECU
But before with the cams both overlaped, i could spin the tires and even with no traction the engine hovered around 7200-7500 RPM untill the car caught traction or caught up, now it will rev to the moon if i let it
