athlete3344
- 450
- 124
- May 1, 2010
Tampa,
Florida
Good afternoon,
Im in the process of putting the rear end back together and found one of the UCA bushings is 2-3mm longer then the rest. Its causing fitment issues with the bracket, but I could probably get it in with some force/more grease.
Is this normal or does the part need to be replaced with one thats the correct dimensions? Part was stamped with same part number as the other 3.
