rear tires chirp in hard turns
Ryan95tsiAWD
262
6
Apr 22, 2002
Goose Creek, South Carolina
Ok so i just replace the intermediate shaft bearing on my car b/c the old one blew up...(long story...shoulda checked the shaft bolts a LONG time ago)
anyway, when i turn sharp (90*) the rear tire on the inside of the turn chirps and the car seems to slow down(like im dragging something)....i have 2 ideas of what it "might" be...
is the new bearing too tight?(not making any noises if it is)
did i screw up the center dif when i was putting the VC back on?
any help or ideas would be great.
A quick search would reveal a million posts on this topic.
When the inside rear tire chirps or hops on slow, tight turns it is an indication of a failing, or locked up center differential. Or you have a welded center differential.
Do you mean the center bearing for the front axle? If so, that goes to the front differential. Why did you have the VC out? It is simple to install the VC so I doubt you screwed anything up there. Failing center diffs are very common with DSM's.
Rick - '91 GSX :dsm:
i had to replace the bearings in the center shaft of the tranny...i have always heard it called the intermediate shaft. The VC has to come out to get to the bearing races that are in the plate between the VC and the center dif
i just talked to a local guru...he said chances are that it is the (most likely) center dif or it could be the VC...so i will start here and see where it goes...
I know i could have done a search for this but it was unlikely that i would find an exact case senario. IE i just finished putting a new bearing on only one of the shafts....
If your intermediate shaft has ANY thrust play in it, it will cause the effects you are getting.
Been there, done that. :(
I wouldn't drive it till it dies, because when it does, chances are it will take out a few other things as well. Unless you're rich, then by all means beat the crap out of it :p
by thrust play you mean that possibly when i put the tranny all back together i may not have put the intermediate shaft bearing on all the way and after i tightened down the outside 36mm nut it came loose(the bearing got fully seated causing the nut to go loose) when i drove the car?!?
ok...so define thrust play...bear with me this is the first time ive messed with the inside of a tranny ;)
  • Wanted 6 bolt NT water pipe
    • chrisman287
