Resolved Rear o2 sensor wire location
kqodprez
289
May 14, 2005
Chicago, Illinois
Hey guys. I'm looking for where to disconnect the rear o2 sensor on my 99gst and I can't find it for nothing! Can some 2g heads chime in so that I can switch this thing out? Thanks!
Also, the front sensor stripped...anyone have any remedies?:confused:
some moron decided it would be a good idea to put in under the driver seat... if your sitting in the driver seat it will be under the carpet close to the center console just infront of the driver seat and the wires go under the seat... you can access it by lifting the lose carpet fron under the center console... i recomend unhooking it from under the car so the wires have some slack
if the sensor is stripped:
vice grips?
if you plan on not using it again, cut the wire and use a "stripped bolt" socket
