rear end rattle
gstdsmeclipse
Sep 13, 2012
king george, Virginia
99 gsx the bolts in the driveshaft came out where it meets the diff and banged around alot (wasn't my fault just got the car). ended up changing out the driveshaft and diff and added solid diff bushings and I have eliminated either half shaft and wheel bearings. the rattle comes in not when im accelerating but keeping the throttle steady 3k is the most common if I completely let off it mostly stops but any ideas would be great thanks oh and whats the gear oil capacity for the rear I just add till it runs out the back but not sure if that's right
yeah i would be under the car banging on some heat shields to see what comes loose.
and yes you just add lube untill it comes out of the fill/overflow.
Im pretty sure its not the exhaust pipe because we had the car up on jacks in the driveway and ran it up to 3k but I will try that
