Rear Driver Side Wheel Hub Rattle
Cheezit033094
87
Feb 25, 2013
O'Fallon, Missouri
Hey guys, I have a very annoying, high pitched rattle coming from my rear driver side wheel hub. It starts as soon as I move and only stops when I hit the brakes. It stays when I'm coasting, cruising, accelerating, turning, or engine braking in any gear, uphill, downhill, or flat ground . when I just barely hit the brakes, is when it stops and starts back as soon as I let off. I've checked for driveshaft play and there is no up, down, left, right, in, or out play. Currently, I don't have a driver side parking Brake cable, as it was broken when I got the car. I removed the driver side Brake caliper and the outer pad fell out when I did. The pads are good, though. There is no axle play, either, or any sway bar play.
DSM Rattle: [ame]http://youtu.be/rdnsuFDwo0k[/ame]
