Rear balance shaft plug
half-cocked
466
Aug 29, 2004
Bullhead City, Arizona
I need to know how to remove the castlated nut that goes over the rear balance shaft seal. I know I can get a special tool but anyting else?
VFAQ says you can use a flathead screwdriver and tap it from the side...Repeatedly.
Why are you taking this off? Are you doing a B-Shaft removal? If so you can still perform this mod without removing the plug at all.
Im putting a new case on and it didnt come with one, so i am reusing the old one. I found the mitsu "special tool" that mitsu no longer sells, available through SPX/Miller. THanks for the info.
  • Wanted 6 bolt NT water pipe
    • chrisman287
