Really need your help guys, i've searched
Ride South
Jan 10, 2006
Portland, Oregon
ok, so recently i replaced the clutch slave and master cylinders. after i did that i noticed that there was a slight surface rubbing noise coming from what seemed to be the tranny. at first is wasn't bad and it would come and go, so i ignored it. not long after i went to the track and did a hard launch. this pretty much meant death for the clutch so i bought an exedy stage 2. i put it in myself. but when i took out the old pressure plate i noticed on the top (side facing into the tranny) there was a lot of scratches and paint removed. i also noticed on the fork there was significant rubbing into the metal where it looks like the fork was making contact with the pressure plate. i can only imagine this is what was making the noise. i was told that it was most likely a bad TOB not holding the fork in the proper place. the fork wasn't replaced, i got everything back together and the noise seemed to have worsened. i don't know why the clutch slave brand new would cause this. or if the fork is bad. but the guys at clutch doctors told me it was bad bearings in the tranny. it's a horrible sound and really only noticable from the passenger side.
it goes away when the clutch is pushed in or in nuetral. i've found other threads with similiar symptoms, but i'm not really experiencing much vibration like they are, and this really started occuring after i replaced the slave and master, and only got worse after the hard launch and clutch. i have no money and this is my only car, so the next repair has to be the right one. please help guys
I had something similar on my car, knocking until clutch is pressed in. Well since i replaced my clutch with an ACT 2100, the knock went away completely. I used a used 2100 Pressure plate my friend sold me, new street disk, new ACT TOB, new retaining clip and new clutch fork and pivot. Maybe this helps..
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
