RC injector users, quick question...
91-gsx
932
11
Mar 31, 2005
San Jose, California
hey whats up,
i have a set of 750cc RC injectors, the only thing is when i got them they did not come with the seals that go in between the injector and the head. do you guys with RC's use the stock seals or did the RC's come with a special one? my injectors are leaking boost and i think it is becuase of the stock replacement seals. so go ahead and tell me which ones you are all using.
thanks
OMG, look where they have their seal located on the injector. mine looks just like that kind of injector style, disk. but my seals are a lot lower then that. here is a picture showing where my seals are, the red area, and you can see right above that is where the seal is really supposed to go. here is the pic:
Someone... either Denso or FIC machine the tip for us. I can't remember who or why.
That tip end looks like a funnel. I would think that as long as the seal to seal distance is the same and you get the dia and plugs righ, you can stick anything in there.
anybody else? comon guys, there are a lot of you running RC's.
I bought mine used and bought new, stock O-rings and seals
you can get them at DiamondStarMotorsport by following the link posted above:
4 injector top o-rings and 4 lower head seals. Select stock type injector body or Fuel Injector Clinic Body. RC Engineering injectors use stock body type seal kit.
Precision Injectors use the FIC style.
