Gruff511
- 196
- 0
- Mar 20, 2011
Fl,
Florida
So I've had this oil burning issue where Randomly every couple days the car will start POURING out while smoke that smells like burnt oil. It will smoke so bad the whole street will be filled with smoke. And at idle it'll smoke the worst And then when I start driving again and burn up all the oil in the cylinders all the smoke will go away and it wont happen again for another couple days. Then when I go to look at the turbo there is Oil around the turbo inlet on the compressor side. So Im thinking that the turbo is blown because the oil in the compressor housing.
I wouldnt think that anything in the head in leaking because the oil I find is only on the turbo inlet? I dont want to have to pull the head and valves out if it's a turbo issue.
