Random misfire issue
KEEBS
Mar 17, 2010
Edmonton, AB, Canada
I have a completely RANDOM misfire? problem also.. Started off running on 2 cyls. changed plugs, wires, coil and module. Fixed it for about a day or 2. Now it starts perfect. It can sit at idle and go from running fine to falling on its face and back randomly... Also while drive it does the same. It seems to run fine at WOT but cruising and at idle it seems like it goes back and forth. No vacuume leaks that I could detet. no loss is boost. Its getting VERY annoying!
yep sounds like a fuel problem to me. get a walbro 255lph and some lucus or gumont fuel system cleaner and get that bad boy running strait!!!:thumb:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
